High-Speed, High-Precision Spring Manufacturing, Custom Wire Forming & Micro Wire Processing
AMADA MEC spring-forming machines set the global benchmark for precision spring manufacturing, automated wire forming, advanced wire forming, and high-speed coil production.
Engineered with multi-axis CNC servo synchronization (up to 26 axes), flexible 3D coiling points, and intuitive MNO2 and MPS touchscreen programming, AMADA MEC equipment delivers unmatched
repeatability, rapid changeovers, and high unmanned productivity across high-mix, low-volume and mass production runs alike. From ultra-fine micro-coiling using wire diameters down to
0.0006 inches (finer than a human hair) up to heavy-gauge wire forming at 0.1023 inches.
AMADA's comprehensive wire machinery lineup is engineered to manufacture
Compression & Single/Dual-Point Coiled Springs (Micro Wire Processing): Powered by the SF, SH, and WH series (including the ultra-fine SF-1A, medical guidewire SH-3AG, and 13-axis WH-2A).
Torsion Springs & Complex 3D Wire Forms: Driven by the DZ-3A, rotating-table TM-8A with 360° tooling access, double-swing LM Series (LM-16A, LM-26A), and the 26-axis NI-26A multi-wire forming center.
Extension Springs with Formed Hooks: Automated via the CLS-10A and CLS-16A series, simultaneously coiling, forming U, German, or English hooks, and sorting finished parts.
Supported by Advanced Automated Pay-Off Reels
(MK-70) and integrated optical inspection systems (ZN-1 and IS-2X camera sensors), AMADA MEC technology ensures absolute dimensional integrity
for critical components—including catheter guide wires and medical coil implants, semiconductor contact probes, EV busbars and automotive suspension springs, and consumer electronics.
Key Technological Highlights
Multi-Axis AC Servo Motor Drive:
Independent servo control across wire feed, pitch, diameter, cut, and arbor axes ensures instantaneous response and precise spring dimensions.
MEC Free-Cut & Tooling Geometry:
Advanced tooling design reduces wire friction, surface scratching, and stress points, extending coil spring life and maintaining spring rate tolerances.
High-Speed Optical & Touch Sensor Gauge:
Automated length-measuring sensors inspect every coiled spring in real time, automatically adjusting pitch dimensions to eliminate out-of-spec scrap.
User-Friendly MEC Computer Program (MNO System):
Visual 2D/3D spring display software allows operators to enter basic spring parameters (free length, outer diameter, pitch) to automatically generate optimal axis motion paths.
Applications & Industries Served
Delivering precision spring coiling solutions for automotive suspension components, aerospace hardware, medical catheters, electrical contacts, and consumer goods.
