CO2 Laser Cutting System — FO 3015 M2 NT
FO 3015 M2 NT
FOM2 NT Standard Features
The FO 3015 M2 NT is engineered to meet the high quality and shorter lead time demands of today’s fabricating companies. Features include the new AMADA tuned oscillator from Fanuc as well as spatter free pierce for higher quality piercing in thicker
material.
- Maximize utilization with minimal setup between jobs
- High speed processing of thin and thick materials
- Operator-friendly windows-based network compatible control
- Performance-proven rack and pinion drive system in the X-axis and high-precision ball screws in the Y and Z axis
- High-speed shuttle table design improves overall machine utilization by externalizing the material setup process
- Cast iron frame for superior stability
- Water Assisted Cutting System (WACS™) uses an adjustable water mist to absorb heat generated by the cutting process
- Cut Process Monitoring for automatic pierce detection as well as plasma detection for thick stainless steel and aluminum
- SFP (Spatter Free Pierce) function for cleaner high-speed piercing in thicker material
- Interlocked enclosure surrounds cutting area to ensure safety
- AMADA/FANUC RF excited resonator provides unmatched performance and reliability
- Automation ready
