Tool Selection
Tool selection is the process by which the system chooses the tools to use for punching the sheet. For punching machines, you must install the tools in the turret. Combination machines require that you designate the cutting head as a tool. You can manage tool assignments using the options found on the Tool menu or Tool toolbar.
Tool assignments are very flexible, allowing the user to:
Note: If you place a tool in a keyed station before assigning tools to a part that is rotated to a different angle in Sheet view than it is in Part view, you should assign those keyed tools in the turret from Sheet view.
Other Help Files covering this subject -
Tool Selection Options Special Tools & Cluster Tool Arrays
Manual Tool Assignment Tool Scribe
Tool Attribute Options (Line Side, Direction & Tabs) Locked Tool Flags
Automatic Tool Assignment Tool Settings
Punch-Outs Keep Tooling
Tool Checking Options
