See the Descriptions below for the PR-C1 Unloading submenu. |
If the unloading sequence has already been set, the user may select this option to reset the entire unloading sequence. Click for more Reset Unload Sequence info.
To sequence the part for an automatic unloading operation, select Auto Unload from the submenu. Click for more Auto Unload info.
This option allows the user to manually unload a part or parts. Click the icon and then move into the work area to pick a part.
| Auto Place Final Hit/Cut | Click to place a final hit or cut. The user must first specify the Final Hit or Final Cut in Sheet mode (Sheet View) before using this function. After a Final Cut/Hit has been placed, the Delete Final Cut button will become active. When using Straight Edge Common Cutting with a combo machine, the user may click a part to place a final cut. Click for more Place Final Hit or Cut info.
Select this option and then click a part on the sheet to display the part remover arm directly over the sheet to specify the location for the arm and the status for the suction cups directly in the work area. When the arm appears over the sheet, double-click a part to zoom in. The arm may be placed at any possible angle. Just place the cursor between the arms, left-click and drag to rotate. When unloading parts to the stacking table, the PR arm treats similar parts, gridded parts and parts in kits or groups as one part. Open the PR-C1 settings window, in order to set other parameters for the arms.
Select View Unload Sequence from the submenu while Sheet mode (Sheet View) is active to check the unloading sequence. See View Part Unloading for more info.
Choose this option to delete the unload sequence for a single part. This will remove the part selected from the unloading sequence, not removing it to the stacking table. Click the option and then left-click a part on the sheet. See Delete Unload Sequence for more info.
| Delete Final Cut | This option is used to remove the final cut from the part. Click for more Delete Final Hit/Cut info.
The Reposition option allows the user to shift the position of the sheet. Note: This option is only used with combo machines, or lasers (such as the Amada Pulsar) that use moving clamps. Click for more Reposition Sheet info.
Click to open the PR-C1 Settings info.
Select to view the editable SY2 file for the current project. SY2 files are auto-generated when the user creates an NC File, and saved in the NCFiles folder in the AP100US installed folder. Note: An SY2 file is part pickup definition NC file that contains part pickup data. When AMNC-IT / FMS is used, the system will output the SY2 file for automation.
Clear All Final Cut |
Click to clear Final Cuts that have been set.
