1. Turret identification
The tool shape in the turret is now easier to identify. Selected tooling is highlighted to make them more accessible to the user.
2. Complex Sequence Redraws Consolidated
Tools redraws will no longer slow down or disrupt Zoom and View Sequence changes, even when a large number of tools are placed and sequenced in the work area.
3. Advanced Loader Compatibility and Configuration
Amada TK & and Amada PR loaders now have default configuration values in the software, to simplify operation. Discover Dead Zone control, Tab Punchouts for improved sheet unloading, effective Auto Final Hit programming and Last Hit speed control for your PRII.
4. FabriVISION Compatible
Output compatible .PRT files for FabriVISION systems. Now you can export native files for the FabriVISION machine.
5. Default Bending Values
Bending values previously had to be redefined each time they were used. Now, the most recent values are loaded by default in the Bend Parameters.
6. Title Display Control
A “Title Display” button appears in the “Color and Style Parameters” tab within Preferences, allowing the user to control the title bar display in the CAD/CAM system frame window. With this button, the user may enable/disable file name display respectively. Also, the user is able to adjust the display order in title bar.
7. Easier Material Selection
The Select Material File dialog box is now resizable and will keep the window size saved. A new Horizontal scroll toolbar is added into the dialog to help read items listed. The Load, Cancel and Browse button will not overlay each other.
