The Area Cut Sequence button allows the user to add a sequence to an area. To do so, click the icon and then drag out a rectangle in the work area on the sheet; all the patterns inside the rectangle will be added to the sequence.
Note: If the rectangle width is less then the height, then the system will use X path width sequence. If the rectangle width is greater than the height, then the Y path width is used. If selecting the first rectangle point, click S on the keyboard, select the second rectangle point and it will use the shortest path to sequence the area (the sequence will start from the corner first selected).
See Area Sequence (for Punch) for more info.
